Why is the Vig 2800 really a 3200?
Old Sep 6, 2007 | 10:04 PM
Tram's Avatar
Default Why is the Vig 2800 really a 3200?
Why did they do that?
Why wouldn't they make the 2800 a 2800 stall?
Old Sep 7, 2007 | 05:27 AM
smoknta's Avatar
Stalls are rated at a certain horsepower. You can take one stall and put it in 10 cars and it will stall different everytime. There are so many factors that play into stall speed, like horsepower, torque, the curves of both, weight, etc, etc. Thats why your best option in picking a converter is to call a company, give them your complete list of specs, and let them recomend a converter for your application.
Old Sep 7, 2007 | 06:22 AM
Omega Doom's Avatar
I concur but sometimes when money is tight you have to get what you can get for the best price!
Old Sep 7, 2007 | 08:45 AM
smoknta's Avatar
That is correct....I found a local company that would make my custom converters, and they are very reasonable and used by many racers here locally.
Old Sep 7, 2007 | 09:40 AM
performabuilt's Avatar
LS1Tech Sponsor
How are you determining the stall speed in your car brake stall and the real stall are not the same thing
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 7, 2007 | 10:22 AM
Tram's Avatar
I've had a Vig 2800 in my car for probably 6 years now, but I always read that a Vig 2800 is really a 3200 stall.. I was just curious as to why that is...
How can I do a brake test and check the true stall? I've read about that somewhere and I thought I remember reading it was not an accurate way of checking?
I've never tested the stall in my car.. I guess I should...
Old Sep 7, 2007 | 03:59 PM
HAZ-Matt's Avatar
Pull it out of the car and put it on an engine dyno.
Old Sep 7, 2007 | 04:14 PM
Tram's Avatar
Yeh, I really don't car that much..
I was just curious as to why they call it a 2800 when it's a 3200..
Old Sep 8, 2007 | 08:55 AM
Travis99LS1's Avatar
If you can put the trans into limp mode...which i think will be 3rd gear..than come to a stop, and just floor it..and watch what the RPM's flash too..this will be close to your true stall speed. You can put it into limp mode by disconnecting power to the trans.
