700R4 and 4L60e - do they interchange?
Old Sep 11, 2007 | 11:04 PM
CarAteMyMoney's Avatar
Default 700R4 and 4L60e - do they interchange?
I'm looking to swap a LS1 into a C4 vette.. it has a 700R4, is this a direct bolt up in terms of the bellhousing/converter?
Old Sep 11, 2007 | 11:08 PM
performabuilt's Avatar
LS1Tech Sponsor
The trans will bolt but you will need a special converter to accomplish this at least bolting to the factory LS1 flexplate
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 11, 2007 | 11:21 PM
can i use a stock 4l60e converter with my 700r4 and mate it to the ls1 without problems?
Old Sep 11, 2007 | 11:23 PM
LS1Tech Sponsor
No there is a spacing issue. and the pilot is wrong , You would need a converter made specifially for that application
__________________
Call 888-744-6542
Old Sep 12, 2007 | 06:19 PM
is there a flywheel spacer you can use?
Old Sep 12, 2007 | 07:46 PM
LS1Tech Sponsor
As far as I know there is a spacer but it will only work with the small dimeter converters, I think you called about a price today on this and no one answered me I will check again in the morning ,
Thanks
__________________
Call 888-744-6542
