Help with stutter with 4L60E @ 75MPH
Old Sep 14, 2007 | 06:38 PM
DFWGrant's Avatar
Default Help with stutter with 4L60E @ 75MPH
Hello -
Today while I was on the highway, I stomped on it to avoid some pain in the *** messing with me. Normally, it would go pretty good with no hesitation...well, this time when I stomped on it, it literally didn't do anything for about 5 seconds before finally accelerating nicely.
It's an 02, pretty much stock with 27k miles on it.
Any ideas? This is the first time I've had much trouble with it.
Thanks,
Grant
Old Sep 15, 2007 | 12:08 AM
DFWGrant's Avatar
Nobody?
Old Sep 15, 2007 | 08:42 AM
jakeshoe's Avatar
Can you get it to repeat?
If so it would be best to put a scanner on it and watch the sensor data to see what is happening.
Old Sep 15, 2007 | 09:52 AM
DFWGrant's Avatar
Well, I tried to earlier this morning and it didn't happen. Maybe I need to change the plugs/wires? Clean/replace the MAF?
Old Sep 15, 2007 | 09:30 PM
DFWGrant's Avatar
Any other opinions?
Old Sep 15, 2007 | 11:18 PM
jakeshoe's Avatar
You can try to throw parts at it and see if you fix it but I would suggest actually diagnosing the cause to save you some $$ and grief.
It could be a TPS issue or a couple of dozen other issues. Put a quality scanner on it and look for faulty sensor data.
Old Sep 16, 2007 | 12:45 AM
performabuilt's Avatar
LS1Tech Sponsor
Agreed on the scanner and it dose not sound like a trans issue.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 16, 2007 | 05:06 PM
DFWGrant's Avatar
Really? We changed the plugs today and it seems like transmission is still slipping a little. However, where would I go to scan the codes at? Or what would I need to buy to scan them myself?
What does it sound like, performabuilt?
Old Sep 16, 2007 | 05:34 PM
jakeshoe's Avatar
You need a quality scanner that will tell you sensor data from the engine, trans, etc.
Most of the cheaper scanners will not do this.
Snap-On, etc. About 2K+ new.
You need a shop with a good scanner or dealership with a Tech II.
Old Sep 17, 2007 | 09:08 PM
DFWGrant's Avatar
Still interested in hearing your opinion, Performa.
Old Sep 17, 2007 | 10:28 PM
Gilbert@Ace Racing's Avatar
Hello Grant,
Gilbert here from ACE over in North Richland Hills.
The severe delay on downshift at highways speeds can be related to several different components. Including engine controls.
We can help you get to the bottom of this set of symptoms. I'm curious, have you been able to duplicate it? if so, do you think you could make it do it again if you were to come by and take me for a ride while I surf the scanner?
Either way.... call me tomorrow. I have several errands early, and then a very busy day lined out. But, I can make the tim eto discuss this with you if you would like to call, say early afternoon.?. Maybe, call early and talk to John, our builder. He may have a suggestion or two over the phone.
We are real easy to find... give us a call and we'll do what we can to get you fixed up asap!
g
Old Sep 17, 2007 | 10:37 PM
LS1Tech Sponsor
I still stay with and engine running issue , Did you clean the MAF , As for scanning for codes any decent trans shop can do that and most general repair garages. I would have this done where ever you end up have them also watch the data stream. Or data log whats happening .
__________________
Call 888-744-6542
