shift kit
Old Sep 15, 2007 | 01:15 AM
V8bamf's Avatar
Default shift kit
if i have a good pcm tune from texas speed will a shift kit do anything for my car?
Old Sep 17, 2007 | 04:26 PM
AK's WS6's Avatar
Yes, it will replace weak stock parts with better ones and that is something that a computer tune will never accomplish.
Old Sep 17, 2007 | 04:33 PM
98_Formula's Avatar
your not putting a "shift kit" in with your tune are you? all that does is increase line pressure.
i had a shift kit put in and recently had my TM 50% deleted in prep for a stall, and it make a big difference.
Old Sep 18, 2007 | 10:00 AM
dwhite02's Avatar
If you have a shift kit installed you may need to have your custom tune adjusted. After I had mine installed the shifts were much firmer and seemed slightly jerky, I had the shift points adjusted in the tuning and it was much better.
