th400 in 2000 Trans Am
Old Sep 25, 2007 | 08:48 PM
ls1sleeper's Avatar
Default th400 in 2000 Trans Am
what i need to put a th400 in a 2000 trans am with a ls2 in it?
need one asap an what i will need trans blew sunday, must get back on the streets a few more times!
Old Sep 26, 2007 | 04:26 PM
Drumer919's Avatar
BMR conversion crossmemember with torque arm mount and a custom driveshaft. Not sure what you need to do to mount the tranny to your LS block though. You can use your stock shifter, it just wont go into 1. Also you will need to convert the tranny to use an electric speed sensor, you could buy the VDO adapter to get your speedo to work but you will loose cruise controll and ABS. If your going to convert the tranny I would recomend doing it before you install it.
Old Sep 26, 2007 | 04:47 PM
SLowETz's Avatar
https://ls1tech.com/forums/automatic-transmission/197642-what-would-you-like-see-addressed-th400-faq.html
