TH400 Bellhousing Question
Old Oct 3, 2007 | 09:38 PM
josh2002-ws6's Avatar
Default TH400 Bellhousing Question
Ok I don't know much about these TH400 transmissions but have been looking into getting one. I found one that has a fixed bellhousing for a LT1. I however have a LS1. I was wondering if they made a adapter to make it fit? Has anyone ever seen one of them and if so where could I get one? Please school me haha.
Old Oct 3, 2007 | 10:45 PM
8a8mfh's Avatar
I forgot the company that has an LS1 bellhousing that allows you to mount a th400 with all eight factory bolts. I requires you cut the th400 bellhousing off. I think they used to be a sponsor but aren't anymore, not sure.
Most people just get an th400 converter with a LS1 crank pilot, or use a flexplate spacer for the regular th400 converter crank pilot.
But this will mean using five engine to trans bolts, I guess it works alot of people do it, same with th350's.
Old Oct 4, 2007 | 10:58 AM
Any of the vendors have anything that will work for me?
Old Oct 4, 2007 | 11:07 AM
408z28's Avatar
??? All Chevy th400s have the same bellhousing, you dont need an adapter to bolt them to an ls1. You just wont use middle passenger side bolt. You will need a crank pilot adapter(if your using a non ls1 converter), but not a bellhousing adapter.
Old Oct 4, 2007 | 11:14 AM
Ok thank you I don't know anything at all about automatic transmission. Just a question for you. I see in your sig that you went from a TH400 to a T56 and now to a 4L80E. Can I ask why?
Old Oct 4, 2007 | 11:25 AM
408z28's Avatar
Th400s are great for staying together and holding power, but not so great when you drive 20 miles on the interstate to work everyday. I got tired of filling up with gas every other day. T-56's are great on the highway and from a roll...but with a 408 you cant launch it without smoking the tires. But a 4l80e has the strength of a 400, plus overdrive. In my opinion the best of both worlds.
Old Oct 4, 2007 | 11:27 AM
408z28's Avatar
It just sucks that it took me about 24 total hours on the floor in my garage, and about $3000 to figure that out!
Old Oct 4, 2007 | 11:49 AM
8a8mfh's Avatar
You don't NEED an adapter. But you do lose three mountng bolts if you just bolt it up.
I was just letting him know there is a bellhousing available that adapts an LS1 to a th400 properly.
FWIW if I was doing the swap I'd use a regular th400 bellhousing and drill and tap holes in it to use the lower section of an LSX 4L80E bellhousing (The thick aluminum dust cover)that also bolts to the engine.
Old Oct 4, 2007 | 12:31 PM
408z28's Avatar
What other bellhousing would you use(other than the "regular one")?? there is only one for a chevrolet th400 and its not like you can take it off.
On a 4l80e you cant run a dust cover (in an f-body) you have to trim the ears off to clear your headers.
Old Oct 4, 2007 | 04:29 PM
8a8mfh's Avatar
REALLY?!!! WOW!!!!
Whats this then.
YEAH it's a th400 WITH A FORD BELLHOUSING!!! can you believe it!!
Which is why they also make a bellhousing like the one above that adapts a th400 to AN LS1!!!
I don't remember who makes it Rossler maybe.
And BTW the aftermarket has made removeable bellhousings for th400's and other transmissions for a very long time.
Old Oct 4, 2007 | 05:01 PM
GMRACER13's Avatar
I don't understand why people use adapters and spacers and such to make the flexplate fit a stock style TH400 converter. Since you have to buy a converter anyway why not just tell the builder of the converter that you'll be putting the TH400 behind an LS1 and they can build the converter to fit with a stock LS1 flexplate. I know Precision Industries can build them that way and I'm sure any reputable converter company can also.
Old Oct 5, 2007 | 07:03 AM
408z28's Avatar
REALLY?!!! WOW!!!!
Whats this then.
Dude...Im talkin about stock case(non race application cases) here. Why would you need a ultra bell on a 600 rwhp car?? Aftermarket bellhousings require a bare case to be CNC machined, you cant just bolt one on...it doesnt work like that
Well the three th400/ls1 set ups i've installed never used anything other than a converter with a longer pilot... so ..... you probably know more than I do??
Old Oct 5, 2007 | 07:53 AM
FLT's Avatar
FLT
I forgot the company that...
I believe the picture that you posted of the bell is from JW Performance. I have used these for glides in fords and also the th400. Nice piece. Vince
Old Oct 5, 2007 | 03:27 PM
8a8mfh's Avatar
No you just cut the bellhousing off and bolt the new one on with longer pump bolts.
CNC is just a fancy word for cutting it off.
No one said anything about HP numbers.
It all depends on how right you want to do it.
