Just installed Vig3600....Trans temp really high any ideas??
Old Jun 7, 2003 | 09:48 PM
99PTA's Avatar
Default Just installed Vig3600....Trans temp really high any ideas??
Yea i just got my vig3600 installed with a polished trans cooler. While running on the freeway the gauge sits at 250 degrees almost off the scale......it varies from time to time but stays in the same 250 degree zone......any one else heard of this??
The trans sensor is not bolted in the trans pan......instead it is mounted in a sensor block roght out of the trans....
the cooler is bolted right on the air damn........it's the polished cooler prt#1307265, capacity is 15,000 gvw,
it's demension is: 11"x4-1/2"x1-1/2
Old Jun 8, 2003 | 12:55 AM
highgear's Avatar
Default Re: Just installed Vig3600....Trans temp really high any ideas??
I use the B&M Supercooler rated at 24,000 GVW mounted in front of condenser. Works great, no problems. You may need a bigger cooler.
Old Jun 8, 2003 | 02:48 AM
Kansas 99z28's Avatar
I also have the B&M supercooler but I have it on the front of my radiator. I agree with highgear you should get a bigger cooler.
Old Jun 8, 2003 | 03:04 AM
42NightZ28's Avatar
i think your guage is reading way to high, mine is mounted into the pan and i have yet to see it go over 170, its normally in the 140-155 range.
i have a BM 24000 and a derale pan running Amzoil Power shift 10w and so far its been great.
Old Jun 8, 2003 | 03:19 AM
99PTA's Avatar
Do yall think that the gauge reading that high ....is dangerous to my tranny...?
Old Jun 8, 2003 | 08:13 AM
Ragtop 99's Avatar
That's way tooooo high.
How do you know the gauge is right? What does ATAP report your tranny temp as?
If the guage is accurate, it is not the cooler size. On the highway you are locked-up and should be generating minimal heat. I would guess that there is an obstruction in your cooler or cooler lines blocking the flow.
Old Jun 8, 2003 | 02:44 PM
99PTA's Avatar
OK ...if i do get it scanned and the tranny temp is lower...whats up with the gauge...and if it reads the same (250 degrees) then what is my next move?
Old Jun 8, 2003 | 03:07 PM
a new gauge. the gauge could be messed up.
Old Jun 8, 2003 | 03:10 PM
99PTA's Avatar
OK checked under the car before a test run....from the front sway bar to almost the oilpan is soaked in trans fluid.....but the concrete under neath the car is dry...why??
Old Jun 8, 2003 | 03:30 PM
Ragtop 99's Avatar
cooler or cooler line leak is my guess. Check your fluid level!
Old Jun 8, 2003 | 04:32 PM
CamaroCain's Avatar
also, if the cooler is mounted on the air dam, how will air flow through it to properly cool the trans fluid, thats why you mount them to the condensor/radiator to have proper air flow trough the cooler, not just across the cooler.
Old Jun 8, 2003 | 07:00 PM
99PTA's Avatar
Problem solved!!!!! it was a bad groound wire in the gauge.....cause this morning i hadnt even strated up the car and the gauge already read 150 degrees..so fidel checked the wires and it was the ground to the gauge. hooked it up and the average temp was 180 to 190 degress.
