can you downshift a rmvb th350
Even with the band it's still extremely hard on the transmission to downshift from 3rd to 2nd from a 45-65 or so roll? Is there anything that can be done about this because honestly that's where I hammer it from the most on the street. Also could this be why my transmission is slipping from 2nd to 3rd now?
I really wouldn't like to loose a foot!
As far as the slippage, that is probably worn clutches, and yes donshifting and hitting it can be abusive to those clutches.
g
You need to rev match a manual to get the sliders to line up with the synchros, etc. Those are hard parts.
You don't need to rev match an automatic because when it shifts it applies a clutch. In a th350 it 'stacks' clutches on shifts, meaning first applies fwd, second keeps fwd applied and applies the second clutch, third keeps fwd, second applied, and applies direct (3rd).
You need to rev match a manual perfectly, all you have to do to downshift a manual th350 or th400 with no front band is have the rpm higher.
This question comes up too much. It freaks everyone out just the mention of it everyone that has or is thinking of getting a mvb starts to panic.
It's not a big deal to learn to drive a new type of trans.
Most likely the damage in the picture came from downshifting after a quarter mile pass most likely over a hundred miles an hour.
After getting used to my RMVB I would not hesitate to drive it everyday if I had to.
