installing mcleod master cylinder question..?????
I've got the heads off my car now and was wondering if this would be a good time to install the mcleod master cylinder, how hard is it to do with the engine together, what'd you have to take off to get it in???, thanks
With the heads and intake off, it is easier to get to than with them on. Take off the master brake booster too ( undo it enough to pull it forward several inches, to be able to get to the clamp holding the stock master in ). And, do the drill out mod since you'll be there already.
www.installuniversity.com. The main thing with the m/c is to bleed it correctly. http://www.phpinc.biz/clutchbleed.html. This worked best for me.
