4L60E Vacuum modulator or not??
Old Oct 18, 2007 | 06:29 PM
mtrhed's Avatar
Default 4L60E Vacuum modulator or not??
Looking at buying new tranny.I have a 2000 Camaro SS with Procharger.I have heard different stories about going vacuum modulated with a supercharger.Is there a reliability factor that goes with vacuum modulator?I have talked to a few companies and some swear by vacuum modulated and others say it causes big problems. What is the consensus here?? Anyone????
Old Oct 18, 2007 | 07:59 PM
Jpr5690's Avatar
i bought a flt tranny with one.. so far it seems to work ok...before that i had a stock tranny and i was happy with the computer controlling it..
all i can say is make dam sure if you go vacc mod it is set up right.. once its in you gotta pull the dam thing to adjust it.. i do miss the ablity to adjust my line pressure as mine shifts less firm then i wanted but being my was setup up my FLT im guessing where it is is probally where it should be
the verdict: if set up right(either way) theres no difference
Old Oct 22, 2007 | 12:33 AM
sobaka__79's Avatar
yeah i dig mine. eleminates a few problem prone parts too...
Old Oct 22, 2007 | 07:41 AM
silver-mod-o's Avatar
Custm2500's #1 Fan
I'll be putting the vac mod in every trans I can from here on out. I love mine. If you are f/i make sure you get the ybpass valve for it though... call FLT, they'll hook you up.
