422 th400 9"rear what gears??? help!
Old Dec 29, 2002 | 08:55 PM
highgmc's Avatar
Default 422 th400 9"rear what gears??? help!
I am selling my moser 12 bolt to get the billingsley 9" rear (the one they have for 8-9 sec. f bodies) it even has it's own swaybar like the wolfe already on it!
I will be running the following set up and need to know what gears to choose for the 9" rear end.
I am thinking something like 3.90 gears?? I don't want to be into the limiter (probably around 7k)by the end of the track. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
mti 422, S1 cam
Tnt 100 shot
rossler th400 with manual vb tbrake and STOCK th400 1st gear
28" et drags
yank pt 4000 (most likely, possibly different converter)
Old Dec 29, 2002 | 11:15 PM
WeatherGuy's Avatar
Default Re: 422 th400 9"rear what gears??? help!
I run out of gear with a 3.73 rearend and 26" drags with a very similar setup, and that's not even spraying it out of the hole. With 28" drags, whatever is close to a 3.73 rearend in the 9" ought to work pretty well. If you go something lower than about 3.90 or so, look to go to 29" slicks or taller.
Old Dec 30, 2002 | 06:03 AM
broke7's Avatar
My buddy with his 355 "300 shot TNT" lt1 95 Z-28 runs a 4.11 in his 12 bolt, he goes 9.58@140 , had 4:30's and was on the rev limiter at about 1100 ft and ran 9.7@133.
He has a 29x10.5 ET Drags
Here is his page with more info, sound kinda similar to your setup.
http://www.exit22.org/warren.html
Good Luck
Old Dec 30, 2002 | 06:30 AM
highgmc's Avatar
thanks for the info guys!
those 29" tires on your buddies car look CLOSE to the fender! that's one fast car! <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Dec 30, 2002 | 07:29 AM
broke7's Avatar
I think he had to bang a little on the underside of the fenders, but other than that no rubbing whatsoever.
Old Dec 30, 2002 | 10:09 AM
nbm00ws6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by terry99ta:
<strong> I am selling my moser 12 bolt to get the billingsley 9" rear (the one they have for 8-9 sec. f bodies) it even has it's own swaybar like the wolfe already on it!
mti 422, S1 cam
Tnt 100 shot
28" et drags
yank pt 4000 (most likely, possibly different converter) </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Go to Car Math and type in for tranny=1.0, tire height,rpms at finish line, and what you think you will be able to mph in 1/4 and let it help you pick the right gear.
Tom
Old Dec 30, 2002 | 11:44 AM
Colonel's Avatar
You have to be careful to take converter slippage into the equation too.
I figured it up for you. 3.89s will get you to 140 MPH trap speeds with 28" tires.
3.73s will get you to 149 MPH.
Basically, how fast do you expect to go?
BTW, I ran 137 MPH with 4.10s but that was with 29" tires crossing the line at 6850 RPM.
Old Dec 30, 2002 | 05:24 PM
highgmc's Avatar
thanks Colonel,
I am thinking with the 100 shot I should be able to run a 9.90 or so hopefully around 135-140ish.
Old Jan 3, 2003 | 05:52 PM
BADZ's Avatar
Moderator
So what yall are saying is that you can't run a 28" tire with a 411 rear and a th350 or you will run into the limiter (7000 mine is now) at the traps??? My limiter will be set at 7200 to 7300 or so....
Old Jan 4, 2003 | 09:57 AM
BADZ's Avatar
Moderator
TTT
