Possable tranny vibration.
Old Oct 27, 2007 | 09:08 AM
'00blackz28's Avatar
Angry Possable tranny vibration.
I had a vibration 50mph+ after running slicks. I pulled the driveshaft took it to a local driveshaft shop it was twisted. I had them retube it got it back, had a worse vibration, they grinded my front yoke to fit the u-jount and took too much metal off and now it moved side to side, took it back. They fixed it and tried to charge me, long story short i didn't pay. Got it back in and STILL have a vibration bad enough to crack a tail housing at high speeds. Question has anybody had this kind of vibration from a 4l60e shifts good up&down doesn't slip or make noise nothing just vibrates. I still suspect the driveshaft. He balanced it with a flat washer
Old Oct 27, 2007 | 09:19 AM
performabuilt's Avatar
LS1Tech Sponsor
I would try and find another driveshaft to try
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 27, 2007 | 09:37 AM
Gilbert@Ace Racing's Avatar
Begin by putting the rear wheels up on jackstands and running it wheels up. Let it idle in any forward gear. Watch the driveshaft to see if there is something obvious.
I am very certain that you need a different driveshaft shop. I would never let a shop grind on a yoke as the likelyhood of them getting it right is very slim. Not sure what they were thinking on that one! Why not get the correct part in the 1st place?
Make sure to get a steel tube as it will be much more durable in the long run if you are running stickies!
g
Old Oct 27, 2007 | 10:11 AM
Default Reply
I ran the car on jack stands and the back section of the driveshaft at the rear end wobbles about 1/8 to 1/4 inch could my pinion yoke be twisted or bent? Has anybody twisted one? I'm running a 10-bolt with 3.73 gears.
Old Jun 9, 2008 | 08:10 PM
LS1Tech Sponsor
It is a possibility and would explain all
__________________
Call 888-744-6542
Old Jun 9, 2008 | 09:16 PM
FLT's Avatar
FLT
Blast from the past^^^^^^^^^^^^
Old Jun 9, 2008 | 09:21 PM
cookba's Avatar
hey Vince how come i dont see yall selling the super hold servo's, spacer plates, accumulator piston kit anymore?
Old Jun 9, 2008 | 09:37 PM
FLT's Avatar
FLT
OK we have just totally................We have decided to suspend parts sales. Basically undermanned to do it. Not only that but the constant tech calls that come with it. Most of which are not our customers to begin with which takes us away from our work. I wish I had time to do it, but building transmissions is what I do for a living or at least that is what they pay me to do! I hope you understand. Vince
Old Jun 9, 2008 | 09:44 PM
cookba's Avatar
haha ya i hijacked a thread from last year that wasnt posted in for near 8 months, ya got me HAHA. I understand Vince, i was just curious cause i love how my tranny felt when i installed all the pieces, its just buying me more time before i buy a Level 3 or better FLT tranny.
