car will not shift into o/d 0753 code
Old Nov 4, 2007 | 01:14 AM
xterminator's Avatar
Default car will not shift into o/d 0753 code
hey guys just a quick question.... i have a ws6 with a stock 4l60e and a tci 3600 converter. i was driving around town tonight and it threw a 0753 code and will not shift into overdrive. first off i thought the 0753 was the 1-2 shift solenoid code? could this make it also not go into o/d? thanks for any help
Old Nov 4, 2007 | 01:37 AM
slagger's Avatar
not sure what code mine threw but it was either my 1-2 or 2-3 solinoid and it went into a safe mode where it use only 2&3 no 1st, or OD
Old Nov 4, 2007 | 05:59 AM
FLT's Avatar
FLT
The 1-2 shift solenoid does come back on in 4th gear. Do you still have first gear?
Old Nov 4, 2007 | 08:30 AM
no it will not go into first or overdrive
Old Nov 4, 2007 | 10:51 AM
performabuilt's Avatar
LS1Tech Sponsor
I would definatly go with replacing the 1-2 (a) solenoid as a first move then ,They are cheap and easy to replace. Go ahead and get a fliter and gasket and change those too while your in there. I ussually suggest changing both the 1-2(a) and the 2-3(b) solenoids as a pair.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 4, 2007 | 12:14 PM
ok thanks performabilt can these solenoids cause the converter to not lock up? it locks up in third gear now but it was just acting funny yesterday before it threw the code. it was locking and unlocking. i found a set of solenoids on ebay for like $20 shipped i guess ill go with that.
Old Nov 4, 2007 | 12:18 PM
LS1Tech Sponsor
The solenoid will likley fix the shift issue but the lockup may be something else entirley , Generally a lock unlock randon situation is due to engine missfire, But I would tackle one issue at a time get it shifting then address lockup if needed ,
__________________
Call 888-744-6542
Old Nov 4, 2007 | 12:20 PM
ok thanks
Old Nov 5, 2007 | 05:29 PM
ybaslo1's Avatar
Try to delete the code first, you might not have to put solenoids in.
Old Nov 5, 2007 | 05:39 PM
LS1Tech Sponsor
I doubt that will help with a PO753 its and electrical fault below if the definition of the code.
When the PCM detects a continuous open, short to ground or short to power in the 1-2 SS valve circuit, then DTC P0753 sets. DTC P0753 is a type B DTC
Your thinking of the stall codes for solenoids stuck open or closed
__________________
Call 888-744-6542
