Tranny Harness
Old Nov 7, 2007 | 05:06 PM
blueeyeddevil141's Avatar
Default Tranny Harness
That big plug on the wiring harness for the tranny(is green inside) how does it connect? I put it on, and it will spin 90*....but it fits loosely, is that right or is there another way.
Old Nov 7, 2007 | 07:56 PM
No one...?
Old Nov 7, 2007 | 08:12 PM
performabuilt's Avatar
LS1Tech Sponsor
I am not sure what you mean do you mean the internal harness? the plug from car?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 7, 2007 | 08:19 PM
No, external. Off the wiring harness for the motor, there is a big grey plug(inside the plug is green) and it is round, and it goes into the top of the tranny above the pan on the passanger side.
Old Nov 7, 2007 | 08:22 PM
LS1Tech Sponsor
it will only set down one way completely and will snap in then unless you squeeze the two tabs it will not come back out , It should not rotate once fully seated .
__________________
Call 888-744-6542
Old Nov 7, 2007 | 08:41 PM
Hmmmm...that didn't go in correctly then haha.
Old Nov 7, 2007 | 09:03 PM
LS1Tech Sponsor
Yep better try again lol
__________________
Call 888-744-6542
Old Nov 7, 2007 | 10:52 PM
Can I get to this plug with the trans in the car, without having to drop the cross member?
Old Nov 7, 2007 | 11:14 PM
LS1Tech Sponsor
With great effort but yes I have done it
__________________
Call 888-744-6542
Old Nov 7, 2007 | 11:15 PM
Errr, easiest way to do this/pointers.
