Pig tails
Old Nov 8, 2007 | 12:49 AM
josh2002-ws6's Avatar
Default Pig tails
I am doing a M6 to TH350 swap right now and was wondering what pig tails will work with the new transmission? I know I can get a speedo adapter for the output shaft but do I need any of the other wire pig tails?
Old Nov 8, 2007 | 02:17 PM
Anyone?
Old Nov 8, 2007 | 05:43 PM
FLT's Avatar
FLT
The speedo one is the only one you will need for the TH350. The only other thing that you will have to figure out is back up lights. When getting your shifter assembly make sure it has the proper switches there for the reverse lights and also a park neutral switch. Other that that I believe that you should be good to go. Vince
Old Nov 8, 2007 | 08:30 PM
98turbls1's Avatar
Do you know which colors and where they are located for both the neutral and back up lights??
Old Nov 14, 2007 | 01:24 PM
RyanA's Avatar
http://shbox.com/1/4th_gen_tech1.html
