T56 shifting less smoothly since 9" install. *DELETED*
Old Jun 17, 2003 | 12:51 PM
timelord's Avatar
Default T56 shifting less smoothly since 9" install. *DELETED*
Post deleted by timelord
Old Jun 17, 2003 | 02:04 PM
timelord's Avatar
Default Re: T56 shifting less smoothly since 9
Just went back to the shop,measured the slip yoke,it is 3.4 inches from the tranny tail to the U-joint center.
I think that is correct and not to tight??
Old Jun 17, 2003 | 06:48 PM
Cal's Avatar
Cal
Well I have a Moser 9 inch in a 2" lowered fbody, and no problems. I wonder if it could be your clutch linkage?
Old Jun 17, 2003 | 08:01 PM
timelord's Avatar
What I don't get is there were no issues before the diff swap.
Will double check linkage and MC related parts,just very odd.
Besides that everything is great,,,,,
Old Jun 17, 2003 | 08:13 PM
LOnSLO's Avatar
Since you deleted the post, I guess you figured it out. I had the EXACT same problem. Turns out my locker creates too much slack in the driveline.
Old Jun 17, 2003 | 08:37 PM
timelord's Avatar
And what was your solution to the problem?
I deleted not to waste space[but it doesn't disappear,so no point in deleting].
Anxious to find a cure for the malady.
Old Jun 17, 2003 | 08:42 PM
LOnSLO's Avatar
My cure as of now is just to live with it. It shifts smooth as glass at WOT, so I can deal with it. I'm currently debating a spool. I still wonder exactly why the additional slack causes this problem.
