Weird Noise
Old Nov 14, 2007 | 07:40 PM
1998TA__1991RS's Avatar
Default Weird Noise
I finally got my motor and tranny going (forged 347/4l60e), Im getting a clanking noise while cranking the engine, once it starts it goes away. i checked all the flywheel and torque converter bolt and they are tight. I called vigilante about it and said it could be the converter not having enough fluid it in, does this sound possible? i filled it up before i put it in the car, but the car has not been up to speed or shifted gears yet. i can also turn the engine over by hand and as soon as i take tension off of the bar it makes the noise.
Any Ideas??
thanks..
Old Nov 14, 2007 | 07:52 PM
performabuilt's Avatar
LS1Tech Sponsor
Fly wheel to crankshaft bolts?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 14, 2007 | 08:10 PM
tight....and torqued to spec
Old Nov 14, 2007 | 08:34 PM
Gilbert@Ace Racing's Avatar
Unbolt the converter from the flexplate, push it towards the trans pump and then try to do the same test with the bar.
g
Old Nov 14, 2007 | 09:00 PM
FLT's Avatar
FLT
Does this car move?
so can i do this with the converter still in the car? so i disconnect the converter through the inspection plate nd turn the motor by hand?
Old Nov 14, 2007 | 09:09 PM
Yes. After unbolting the converter from the flexplate, slide it back and make sure there is clearance between the converter and flexplate prior to rotating the crankshaft.
Also, rotate the converter after unbolting it to see if you hear anything obviuos. You are also looking to see if it is difficult to rotate by hand.
Yes, the goal is to determine if the noise is in the engine or the tranny / converter.
Vince has a very good question... does the car move?
g
Old Nov 14, 2007 | 09:34 PM
yes the car does move, it has an aprox a 4600 stall in it and i have to rev it to about 4000 to get it on the trailer
Old Nov 14, 2007 | 09:35 PM
also does the tranny have to be in neutral for the converter to spin? sorry i don't know too much about trannys
Old Nov 14, 2007 | 09:37 PM
No the tranny does not need to be in neutral for it to rotate.
g
Old Nov 14, 2007 | 09:42 PM
ok i will check this out tomorrow and let you guys know. thanks for the help
also if it is coming from the tranny what could it be?
