Tranny cooler
Old Nov 20, 2007 | 07:34 PM
tording99Z28's Avatar
Default Tranny cooler
So everyone has said that a tranny cooler will help with the life of the 4L60E so my question is what is the most common cooler that most guys go with, hopefully one that won't break the bank but get the job done for cooling off the tranny. Where is a good place to pick one up?
Old Nov 20, 2007 | 08:54 PM
super_fro_daddy's Avatar
The easiest way would be to go to the local parts store and buy one there.
I currently run the B&M 24000 Part # BMM-70264
BTW, before someone else tells you - I would use the search feature, even though I am not a fan of the new setup, but thats neither here nor there.
Last edited by super_fro_daddy; Nov 20, 2007 at 09:23 PM. Reason: possible non-sponsor link removal
Old Nov 21, 2007 | 03:02 PM
radz282003's Avatar
I have two of those coolers and have never seen my temp's above 180* at the track.
Old Nov 21, 2007 | 03:46 PM
sroach20's Avatar
i got a hayden rapid cool from a local auto part store. it keeps my stuff cool.
Old Nov 21, 2007 | 04:12 PM
koolaid_kid's Avatar
I have the B&M also, very pleased with it.
Just be sure and bypass the radiator "cooler". It only adds heat, and is not necessary when you mount an external cooler.
Old Nov 21, 2007 | 04:24 PM
cryptnosis's Avatar
i have a 24000 B&M as well as a 22000 transcooler and disconnected the 22000 because people were telling me that you dont want it to run to cool, was a a lie?
Old Nov 23, 2007 | 06:35 AM
ChevyGoldfinger's Avatar
Not exactly a lie depending on what part of the country you live in. If you live up north and try to use the double cooler setup, you might not be able to get the trans up to operating temps. If you live here in Las Vegas, or maybe Phoenix, the double coolers would probably be fine in winter and the trans would love you in the middle of summer.
Old Nov 23, 2007 | 08:35 PM
I got a Hayden rapid cooler from pep boys. Its the big boy #679 that is used on Class A RV's to tow 10,000 lbs so hopefully it will keep my little 4L60E nice and cool. I am planning on unhooking the stock radiator cooler and only use the external cooler since winters in Virginia are not that cold.
Old Nov 24, 2007 | 12:24 PM
Thats what I have been thinking. I just got a new Performabuilt trans and want it to last AS LONG as possible. I currently run one cooler. I plan on getting the Aeroforce gauge soon so I can monitor it. Then next summer I'll do a little testing to see how two coolers work.
Old Nov 26, 2007 | 07:07 PM
cryptnosis's Avatar
Ok well i might hook my second back up, i am in hawaii and its summer 24/7.lol
