A few A4 Conversion Questions
Old Nov 22, 2007 | 01:02 AM
Sinister95Z's Avatar
Default A few A4 Conversion Questions
I am in the middle of a A4 swap in my 95 LT1 Camaro. I got the old T56 out and sold. Now I am getting the car prepared for a stage 2 Performabuilt going in about two weeks. I have a few questions and part number inquires that I would like to run by you guys.
I bought a SFI approved flexplate and ARP flexplate bolt kit. Part #200-2906. Are these the correct bolts and what should I use on the threads to make sure they do not back out? Red Loctite?
There is a bearing inside the rear of the crank. Should I take it out? If so, what is the easiest way to get it out without damaging anything?
I did not recieve any bolts with my Yank converter. Does anybody have a part number that I can use to buy these? I want the best ones that I can get. Should I use loctite on these bolts as well?
Sorry for all the questions, I just want to do things right the first time around. Thanks for any and all help.
Old Nov 23, 2007 | 12:39 PM
Any help? Anybody?
Old Nov 23, 2007 | 07:32 PM
Ragtop 99's Avatar
Yank used to supply the bolts. Call them and ask them to overnight them to you if they dropped the ball on this.
Old Nov 24, 2007 | 02:04 AM
It is not a downfall on Yank's part. I bought a very slighty used converter. Can you happen to help me with these other questions?
Old Nov 26, 2007 | 03:15 PM
I know these are very small easy to answer questions, but I could really use some help here guys. I want things to be done right.
Old Nov 26, 2007 | 05:07 PM
Circle-D's Avatar
Converter Info:
Factory threads are 10 x 1.5mm. I order them from my supplier and they come with a locktite coating on them. If you can't find any local let me know.
