How hot is too hot for auto tranny?
My question, is 190-200 too hot? What is an ideal temperature?
Anything over 175* is getting sorta hot, my truck with the factory cooler hits around 155* via AutoTap and a 195* thermostat. That temp worries me and is why I will install a bigger cooler (7"x14") inline with the stocker.
Now, engine oil temp needs to be around the high 180's from what I remember.
Keep the cooler hooked up.
The cooler lines to the radiator run to the hot side (return side) of the radiator. Why didn't the factory run those line to the cool side so the tranny would run cooler? Maybe it will last longer in the 180 range. This is what it run in normal driving. Very close to engine temperature.
I use Auto Tap to read my temps and everything else.
99PTA,
A PI 3600 is what I have. I have hooked my cooler back up but have not taken any readings with my current set up. I tried with the cooler under the car without the fans and it ran almost as hot as no cooler in traffic. I have the cooler where the fans will draw across it now.
