weird problem
Old Nov 24, 2007 | 11:35 PM
1998TA__1991RS's Avatar
Default weird problem
I got my car on the road today and i hve no first or fourth gear. I can shift it manualy into 2nd and 3rd but 1st and 4th will not work. the tranny was working fine when i pulled it out. i looked at the electrical connections and the yellow plug on the side of the tranny has no wires connected to it, looks like they broke off when we were putting the tranny back in. what does this plug control. also my odometer doesnt work, could this have anything to do with it? thanks in advance
Old Nov 25, 2007 | 12:17 AM
performabuilt's Avatar
LS1Tech Sponsor
Repair the wiring and you should be fine if not holler back and ill be happy to help you
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 25, 2007 | 07:10 AM
FLT's Avatar
FLT
Sounds like they broke your speed senor off. As mention above get it fixed and you issue will more than likely be resolved.
