Will changing rockers screw with my converter?
I have stock rockers, and am thinking about going to 1.8's. I know it will change the lift on the cam, which is currently a 222/224 .566/.568 @ 112. I have a TH400 with an ATI 4000 stall converter. Can I do the new rockers without screwing my converter. I know one of the determinig factors of what stall to get on the converter is the size of your cam. 'Lil help.
No material gain in torque that would effect your stall.
You have an odd combination - a small cam but a hardcore tranny set-up. Are you spraying?
Why not put a more agressive cam in rather than rockers; the HP/$ for rockers isn't very great where as a little bigger cam with .600 lift will put some decent power in.
