Speed Sensor for TH400???
Old Jan 13, 2003 | 08:37 PM
Phate's Avatar
Default Speed Sensor for TH400???
Guys,
I am going with a TH400 in my former 6-speed car. What do I need to do to get my speedometer to work with the 400?
Thanks,
Scott
Old Jan 13, 2003 | 08:40 PM
BIGBOS's Avatar
Default Re: Speed Sensor for TH400???
Call up Yank and order a Yank speedo sensor, thats what I have on my car...there is slight lag at the beginning, but then the speedo catches up right away... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 13, 2003 | 09:39 PM
CONFUZED's Avatar
bigbos,how much was that set-up?did you have to have a gear put on the output shaft on tranny?did you have to change anything with ls1 edit?i ran a few g.m parts #s for speedo gear/sensor /pigtail.speedo workes just like stock.but we had to fudge the gear ratio on ls1 edit.(basically speed sensor i used doubled speedo reading)so we played with gear ratio/tire height,now speedo is correct.about $100.00- $120.00 in parts
Old Jan 13, 2003 | 09:43 PM
BIGBOS's Avatar
I forget how much the Yank sensor was, but it runs off of a gear I believe....its right on target, except for when I run my Hoosiers in the back.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 14, 2003 | 07:22 AM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
I have been emailing a guy (Jim Hogan) who was one of the first guys to make this swap. He also has a Gear Vendors OD. What he told me was swapping from an A4, your speedo will be dead on. Swapping from a M6, your speedo will be 2.4 times off.
You will need a 40 tooth reluctor wheel for your tailshaft, and a VSS, which takes the place of the cable drive sensor.
Tim
Old Jan 14, 2003 | 10:11 PM
highgmc's Avatar
I bought the yank sensor, I don't have the # but it's just a gm part from a th400 truck (1989 I think) <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Jan 15, 2003 | 11:19 AM
Phate's Avatar
Thanks for all of the replies guys, I will give Yank a call.
Scott
Old Jan 28, 2003 | 03:12 AM
strife's Avatar
anyone know what the yank price, ive buzzed them a mail but nothing back yet
or the part numbers ?
thanks
Old Jan 30, 2003 | 03:52 AM
strife's Avatar
still nothing back from yank
can anyone assist
TIA
Cam
Old Jan 30, 2003 | 07:20 PM
ElkyRacer's Avatar
Just go to a dealership, and get the reluctor wheel and a speed sensor from a 93 or 94 Chevy 454 truck. I do belive those came with the 400s. If not, just go back a few years.
Kyle
Old Jan 30, 2015 | 10:37 PM
tarponhunter428's Avatar
Default Turbo 400 speed sensor
Hey guys hoping for some help. I am finding a lot of old threads on a turbo 400 swap. I am having problems finding parts for the vss. The part is discontinued from gm. Does anyone know another solution to run the speedo?
Old Jan 31, 2015 | 04:22 AM
nj02z's Avatar
How is this
https://ls1tech.com/forums/automatic...350-th400.html
