Variable Pitch Converters
Old Jan 14, 2003 | 05:35 PM
Phate's Avatar
Default Variable Pitch Converters
Hey Guys,
The guy that is putting together my trans wants to use a variable pitch converter in the car...supposedly the car will stall at 2000 on the street and then stall at 3000 with a flip of a switch.
Anybody else using one of these?
Thanks,
Scott
Old Jan 14, 2003 | 06:32 PM
Colonel's Avatar
Default Re: Variable Pitch Converters
Ask him if he can make it 3000 and 4000 instead. That would be ALOT more useful...elsewise you'll end up leaving the switch set to 3000 all the time.
Seems like I heard variable pitch converters are very heavy?
Old Jan 14, 2003 | 06:45 PM
Phate's Avatar
He said that if I don't like the way that the 2000/3000 works then we can go with a 2500/3500 at no cost.
I got the feeling that there was a limit as to how high you could go with the stall for these...is that true?
Scott
Old Jan 14, 2003 | 08:57 PM
Ragtop 99's Avatar
I agree with Colonel, go higher. At least do the 2500/3500 version.
Be intersting to see if your efficencies dies on the higher stall speed; That's a pretty big spread.
Old Jan 15, 2003 | 12:51 AM
WILWAXU's Avatar
Yeah.. would be interesting to launch with the looser setting, then flip the switch to tigher for a better MPH on top end <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 15, 2003 | 11:18 AM
Phate's Avatar
Well, the guy is going to build both of the converters and we are going to try them both in the car to see which one we like better.
I will report back on how it goes. The thought on the 3000 was that my car makes full boost (8psi) at 3000 and that is where I am going to leave on the brake.
Thanks,
Scott
