Manual Valvebody...
Old Dec 10, 2007 | 08:07 PM
RearMountKing's Avatar
Default Manual Valvebody...
Im going to put a MVB in my 4l60e, with this mod, will the shifts be on demand...?
I want to be able to put it in a gear and it GO to that gear, with no lag...
Whats the best way to do it?
Thanks in advanced....
Old Dec 10, 2007 | 08:50 PM
eric01ss's Avatar
this would be it and would put less stress on the tranny and u can get rid of the shift points since u will shift it now
Old Dec 10, 2007 | 09:18 PM
Awesome!
Old Dec 10, 2007 | 09:19 PM
Also, would the tranny specs on the Computer need to be erased?
And would there need to be a rpm max set with fuel cuton and off.?
Old Dec 10, 2007 | 09:20 PM
eric01ss's Avatar
tranny shift piint just need to be erased
Old Dec 10, 2007 | 09:37 PM
Sweet. So thats the only thing that needs to be erased... I have HP tuners, just wanted to make sure thats all there was!!!
Oh yeah and thanks for your help!
Old Dec 10, 2007 | 11:23 PM
Gilbert@Ace Racing's Avatar
Who's kit are you going to install?
The reason I ask is that there is quite a bit more to it than Valve Body Mods. I highly recommend you install all of the components in the kit. We use the Trans Go HD-3 kit. It incorporates all of the -2 components and adds a Vacuum Modulator for line pressure control. It is a very thorough kit. I really do enjoy building these units! We have had great success with them.
Good Luck with it!
g
Old Dec 10, 2007 | 11:36 PM
00Formula00's Avatar
I'm installing my trans in my garage right now that will have a MVB in it, I'll let you know how it goes
Old Dec 10, 2007 | 11:42 PM
Well I bought this valve body off of a member of another board, and it was the WHOLE valvebody.. Not a kit.. .Its the whole replacement VB
Old Dec 12, 2007 | 05:32 PM
STOCK12SECZ's Avatar
Good Luck with it!
g
How is the shift firmness with this kit (HD-3)? And what controls the lockup once you install it..If I have a M6 and convert to a 4l60e with this kit will I have to wire up my own lock up switch? Im not wanting to switch to a auto wiring harness. Thanks for your help!
Old Dec 12, 2007 | 10:04 PM
There are only two significant differences between the -2 and -3 kits.The inclusion of a 46 Mod (Vacuum Modulator kit) and the Manual conversion components. It is a very inclusive kit.
Lock-Up is not affected.
Yes you will need to hardwire a lock up switch if you do not go with a stand alone controller or conversion harness. Those harnesses are not that expensive... usually under $300.00 through Speartech.
g
Old Dec 12, 2007 | 10:46 PM
performabuilt's Avatar
LS1Tech Sponsor
You can alternatley use a 700r4 lockup kit and the factory harness ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 13, 2007 | 12:29 AM
brandon1221's Avatar
Just wondering do you all use the stock shifter with manual valve bodies or do you use a different shifter such as B&M? Also does it have to be a fmvb or can it be a rmvb?
Old Dec 13, 2007 | 12:30 AM
LS1Tech Sponsor
To the best of my knowledge thee is no RMVB for the 60/65e
__________________
Call 888-744-6542
Old Dec 13, 2007 | 07:39 AM
I was thinking the 700r4 lockup kit. Can it work with the factory m6 harness? thanks again
