Tranny issues?
Old Dec 15, 2007 | 03:35 PM
Blackj98's Avatar
Default Tranny issues?
will putting a TCI 3800 stall on a stock 4l60e screw with the tranny?
Old Dec 15, 2007 | 04:49 PM
performabuilt's Avatar
LS1Tech Sponsor
If there trans is in good shape you should be ok , However you may require some tunng for shift points and possibily deletion in the tune for code PO757 is the most common issue. Also you may want to eliminate PWM in tuning as much as possible.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 16, 2007 | 11:15 AM
Blackj98's Avatar
thank you very much.....will hpt do that?
Old Dec 16, 2007 | 11:28 AM
LS1Tech Sponsor
I beleave so but I am not a tuner, But it should.
__________________
Call 888-744-6542
Old Dec 16, 2007 | 11:40 AM
Blackj98's Avatar
awsome..time to start working on it then, thank you
Old Dec 16, 2007 | 10:58 PM
LS1Tech Sponsor
Your Welcome
__________________
Call 888-744-6542
