Ever Wonder What Goes Into An ACE 4L60E?
Well here ya go, this is what you are paying for at ACE Racing Transmissions. We had a bench open when we received a large delivery earlier this week. So I took some time to take these pics.... These are the exact same parts that went into the unit out of a '97 Camaro SS. It was towed to us after shredding his Input Drum on the hit. It was delivered to the customer today. He picked it up just before noon. Nice car Ryan, thanks for the opportunity!
These are most of the new parts that we install into each and every...not just some units... each and every ACE Racing Transmissions Stage 2 4l60E. The big box standing up in the picture is a Trans - Go HD-2 Reprogramming Kit. Not all bushings, accumulator pistons, sleeved input drum and other components are shown in this group of pics. I'll get them up at a later date.
![](http://i220.photobucket.com/albums/dd165/ratchthed/DSC03438.jpg)
This unit received a Carbon Fiber Band. We also install the Alto Red band. Bands are chosen solely on the application. Borg Warner Low Roller/ Rear Sprag, and notice the Dual Cage Input sprag. Beside the Low Roller are the Hardened Pump rings and a Hig Rev pump slider spring. These rings are cast iron from GM, we install the Steel rings as they are less likely to fail in high stress environments. There are several different pump slider springs to choose from. We will determine the best spring for your application.
![](http://i220.photobucket.com/albums/dd165/ratchthed/DSC03439.jpg)
These are just a few of the bushings required to build a 4L60E. Each bushing is hand fitted and hand polished prior to final assembly. Notice the Teflon coated Frt pump bushing.
![](http://i220.photobucket.com/albums/dd165/ratchthed/DSC03440.jpg)
The Beast Sunshell looks discolored because it is straight out of the box. They come shipped with an anti rust agent on them. All new electronics... harness and solenoids pictured. Vacuum Modulator and related components. 3/4 clutch pack thrust and reaction plates.
![](http://i220.photobucket.com/albums/dd165/ratchthed/DSC03441.jpg)
This is called a Paper and Rubber kit. AKA all of the seals it takes to do the job right the 1st time. We never recycle any seal or filter, never.
![](http://i220.photobucket.com/albums/dd165/ratchthed/DSC03443.jpg)
Notice the new T/G Valve Body plate? We do not install used, refurbished, sanded down or worn out has been valve body plates that have been in service for years on end. Ask your builder what he installs. Then ask him why. These new plates will be modified based on the given application.
![](http://i220.photobucket.com/albums/dd165/ratchthed/DSC03451.jpg)
We feel that when you ask us to build your High Performance 4L60E you are asking for the best that we can provide. Not just a unit that will get the job done, but one that will take the hit time after time!
If you live nearby and are curious about what components go into one of these transmissions please do not hesitate to come by and see for yourself. Each and evey customer we have ever had at ACE has been invited into the shop so that they can see what goes on behind the scenes!
g
g
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
LoL ... while I cannot deny nor confirm the inclusion of any Manley valvetrain components.... I can say we do make custom and proprietary changes to the hydraulic circuits in our transmissions.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
g
Gilbert, i meant to stop in last week to meet you in person & to tour your shop. Unfortunately the weather did not permit me to do so.
I plan on stopping in this week, oh and like the other guy.. TAX time is coming and i will surely be dropping my car off for a few days for a much needed "tranny" rebuild.
See you soon.
See you soon.
Replied All Ull C
Thanks for asking 2020.... because we use OEM 5 pin planets and have options for billet shafts. We can take a 4L60E well into the 800 h/p range. But they become high maintenance at that level.
As far as an 80E is concerned... you bet, we build those as well. I have a pretty stout unit ready to go... it has not been picked up by the shop that commissioned it to be built. So, until they do pick it up it is for sale. We can build you a converter as well.
We'll take care of the R&R for you if you can get me the car.
We do charge for conversions. But we do them correct.
Feel free to call me tomorrow... I'll be in mid morning. I have to drop Mrs. Ratchthed off at the airport. After that I'll be in all day.
g
g
She hates flying! And she is heading to California for the week. We had to get up at 4:00 a.m. so I could get her to the airport by 6:00 for the 8:00 a.m. flight. It's gonna be a long one today.
How 'bout you buddy? How's the weather over there in Arkansas.... Mr. I took the week off?
g
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
