4L60E pump bolt part number?
Old Dec 16, 2007 | 07:21 PM
98blackSS's Avatar
Default 4L60E pump bolt part number?
Does anyone have the P/N for the pump-to-case bolts? I need to order one. They are the M8 x 1.25 ones that have the o-ring indents on the back side of the bolt head.
Thanks in advance
Old Dec 16, 2007 | 07:54 PM
Gilbert@Ace Racing's Avatar
I would recommend swinging by a transmission shop and asking them for the bolt.
You could also swing by a GM dealer and thye could get it for you.
g
Old Dec 16, 2007 | 08:21 PM
98blackSS's Avatar
g
No dealer by me unfortunately.. Could try a trans shop though. Who knows with this small county though. Are they common?
Old Dec 16, 2007 | 09:01 PM
Yep... millions of those trannies were built. So that must mean there are a bajillion bolts!
Call me tomorrow and I'll hook you up. I did not know you had limited resources.
g
Old Dec 16, 2007 | 10:37 PM
performabuilt's Avatar
LS1Tech Sponsor
Agreed they should be very common goto a trans shop tell then you need a 4l60e pump to case bolt they will likley have plenty , May even give them to you I would
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
