3000 Vigilante Converter, 1st gear pull off
I had some problems with my tranny this weekend pulling off in second gear. However, this problem should be fixed by the end of this week. Anyway, you guys with the 3000 stall converters WHAT RPM'S YOUR CARS GO TO WHEN PULLING OFF IN FIRST GEAR???? I was just curious on what I can expect when everything is working properly. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Under daily driving conditions with a 3000 stall you should expect to use at least 1800 rpms and as much as 2600 rpms if you are pretty far into throttle with around 2000 - 2200 being typical.
