help me pick better stal for my th350!!
Old Jun 28, 2003 | 12:25 AM
TApimp's Avatar
Default help me pick better stal for my th350!!
setup consits of 218/222 581/569 on 114 cam, mild ported heads, tnt nitrous kit should be at around 150 shot
9 inch with 3:70's car is easily around 3600 pounds
i have a ptc 3500 stall, but i can foot brake it all the way up to around 3400, so i think it may be a little to big for my app. can anyone help me out?
Old Jun 28, 2003 | 08:40 AM
Ragtop 99's Avatar
Default Re: help me pick better stal for my th350!!
spray it and see where it goes. From there you can decide if it is too big.
Old Jun 28, 2003 | 08:50 AM
Kevin Winstead's Avatar
I'd send the PTC converter back and get it restalled. Kenny does a pretty good job on his converters. If you're footbraking 3400, then it's flashing alot higher. Do like Ragtop suggested and see where it flashes on N2O. I'd like to see a flash stall of no more than 4000 on motor and no more than 5000 on juice, preferably a couple hundred less than that...those TNT kits hit pretty hard.
Kevin
