th400 which trans mount?
Old Jan 21, 2003 | 09:19 PM
highgmc's Avatar
Default th400 which trans mount?
I will be using either the yank or bmr trans xmember. I want a poly trans mount, just get one for a th400?
thanks!
Old Jan 22, 2003 | 10:43 AM
MacGyver's Avatar
Default Re: th400 which trans mount?
I'm using an energy suspension poly mount with my BMR crossmember. I think it's part number 355-3-1108G from jegs.
Will
Old Jan 22, 2003 | 10:48 AM
highgmc's Avatar
thanks Will, is it just a th400 mount?
Old Jan 23, 2003 | 12:41 AM
MacGyver's Avatar
Yes any old style TH400 mount should work with it. I think i might have had to grind a little bit out of the holes on the BMR x-member with a dremel to get it to fit. But mine was one of the first ones that brett ever produced so that might have been why.
Will
