Pressure issue???
Trans has been rebuilt about a year and half ago and has a transgo shift kit and clutches and band have all been replaced.
Car has only been used for short distance driving, no WOT launches as I have yet to get a tune. In case it helps I also have a 2800 Vigilante stall and a trans cooler all hooked up.
Does this sound like only an issue with the pump or a stuck valve? Maybe a check ball wearing through???
Any help appreciated.
Speedo is working but is off right now. Previous owner had 3.42 gears put in and not tuned. That's why i have only used under normal acceleration. I didn't know it wasn't tuned for those gears and I gave it WOT and fried the trans which was the reason for my first rebuild.
After a few miles on the highway and going through a bunch of stop lights, it finally started acting up shifting into second again.
I'm really hoping it's something that can be resolved without having to drop the entire trans so valve body and servo will be checked first. Any other suggestions?
Solenoids have also been checked and are working properly in all other gears.
His guess is the servo or band but isn't sure because he says he has not seen the modifications that have been done to my servo before in his experience, so therefore he does not want to touch it.
So if it is the ECM is it something that can be resolved by tunning or is my ecm just screwed?
One more thing in case it matters, he said he did check the solenoids out of the trans (not just per scanner) also and they checked out.
*EDIT...more info, he said in the 1-2 accumulator (sp?) there were two springs and in his experience there should only be one. He said it was one spring, the piston, and the second spring. I would assume this was an intentional mod but i'm just putting it out there in case it helps.
1st= "A" & "B" on,
2nd= "A" off "B" on,
3rd= "A" & "B" off,
4th= "A" on "B" off
The shift, TCC, and 3-2 solenoids are powered from the same source (PCM ign fuse) which is the pink wire going into the tranny plug. The PCM grounds the solenoid that it wants to engage for a particular shift. My guess is the "A" solenoid ground (light green wire to the tranny plug) is grounding somewhere, keeping the "A" solenoid on when its not supposed to be. Shake out that harness and see if something different happens. Take a look for more pinched wires. Most likely your problem will be something in this order.
Mec
1st= "A" & "B" on,
3rd= "A" & "B" off,
4th= "A" on "B" off
Mec
I'll keep everyone posted on the results for future reference.
Regardless it should still work with one I know but he said while the car was up in the air he truned it on and gave it gas and it is shifting. I guess he is implying that without any load it's holding and able to shift.
Not real concrete if you ask me because as I said before when I drove it over it worked fine for a while as well.
As far as the wiring he said he had not found any issues with it grounding out or being pinched. On his scanner no codes were being given. He said he drove it around and manually shifted and it was working, but shifting into 2nd was not firm at all.....
When I asked about that he said when he put everything back and tried it again it was working just very softly. Doesn't make sense I know, but in case it is not electrical I wanna see what he is trying to get at.
Apparently the 1-2 accumulator checked out and he was unsure about the servo as it was moded in a way he had not seen (extra plates and 4 holes drilled?), but then again he said the pressure checked out as well, so to me he is implying it needs to be opened up and have the band looked at....
Now adressing the servo the shims ajust the band clearance for second and are from the transgo kit. The holes or slots i the cushion retained are to help eliminate part throttle slam caused by the plate there becoming hydraulically locked solid in place also a transgo mod. I dont think you ever answered but how does the 3-4 shift feel that will give a good indication of the condition of the band?
