question with my shifter 4L60E
Old Dec 26, 2007 | 04:11 PM
scottie dont's Avatar
Default question with my shifter 4L60E
hey yalls im puttin in my mega shifter and i just got my short stick (2" shorter then the normal auto stick) the gate adapter (3spd to 4spd auto) got most everything i need. but on the factory shifter on the right side there is a module that tells the tranna if its in part or gear. can i leave that in the park position so that it will start or will that mess anything up in the computer? cuz B&M does not make a plug in module for that to go on the aftermarket shifters. sorry for the dumb question but id rather ask it now then find out i was wrong later. thanks
- Scottie
Old Dec 27, 2007 | 07:29 PM
to the top
Old Dec 27, 2007 | 08:57 PM
performabuilt's Avatar
LS1Tech Sponsor
I think thats your prndle switch are you usig the 4l60e if so that will have to work , If your uning a 3 speed I am not real clear on the swap your doing then you could leave it in the park position
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 28, 2007 | 12:09 AM
im running a 4L60E. i was told that the switch on the right side of the stock shifter (has 6 tabs i believe) tells the computer that the car is in park, reverse, overdrive or drive. so i would have problems with the transmission upping the line pressure in lower gears and the lock up converter locking up if i leave it in park.
Old Dec 28, 2007 | 10:15 AM
LS1Tech Sponsor
Yes you will indeed need that to work for the transmission to work properly
__________________
Call 888-744-6542
Old Dec 28, 2007 | 10:27 AM
Hmm so how is everybody else running aftermarket shifters cuz i dont see any way to adapt this to the new shifter?
