Please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!! doing engine swap!!!!!!!!!!!!
Old Dec 31, 2007 | 11:03 PM
jerons94camaro's Avatar
Default Please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!! doing engine swap!!!!!!!!!!!!
Are there any previous or later year models that I can take the engine and trans out of and will fit into my camaro without having to replace too much. From what i have heard i should be able to just drop the LT1 engine right in and and not have to replace the motor mounts, just the trans (as you have said), ecu, some sensors and possibly the wiring harness if I and they are correct.
:mullet :
Old Jan 1, 2008 | 07:42 AM
FLT's Avatar
FLT
The best way to do this is to find a totaled donor vehicle. Everything is there to do the proper swap. Just an idea. Vince
Old Jan 1, 2008 | 10:58 AM
02NBMFormula's Avatar
this might help you out. http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
Old Jan 1, 2008 | 08:34 PM
Thank you so much this helps out like no other
