4l60 transmission doesnt down shift correctly
Old Jan 2, 2008 | 04:54 PM
eduardo's Avatar
Angry 4l60 transmission doesnt down shift correctly
i have a 98 ls1 camaro a4 built..it has a transgo shift kit. when im driving and down shift to 1st it doesnt down shift . it stays in second gear. and when i try to launch it like around 1500 rpm when i take off it takes off in second and doesnt shift at all till i get to about 90 miles an hour. once in a while it will take off in first when the car is cold but when its hot it only takes off in second when i try to launch it.. when i drive it normal it does excellent shift good and everything..anyone have an idea to what may be the cause of this problem..thanks alot
Old Jan 2, 2008 | 05:03 PM
performabuilt's Avatar
LS1Tech Sponsor
Could be several things ,Did this happen imediatly after the build? or did it work fine a while then start this?And are you getting any SES check engine lights?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 2, 2008 | 06:57 PM
eduardo's Avatar
no check engine light now, when i first got the transmission there was a check engine light on, the transmission was only taking off in third gear, i took it back and got the problem fixed, then the check engine light came off. when this was happening it kept on buring out the some fuse which i forget which one it was. then after that when they fixed it i took it to the track to see how it would run. that is when i noticed that it was taking off in second gear. my 1/4 times was like 14.4 being my worst . oh yea and if it has anything to do with it. i did notice at the track a light would come on that would read something like no traction or traction low. but its kinda funny because my car is a z28 with no traction control..
Old Jan 2, 2008 | 07:07 PM
LS1Tech Sponsor
Well sounds like you possibly may still have some electrical issues I would take it back again, If the shop has a shafter shifter have them put the trans on it first and drive and make sure it can make all the gears consistantly to eliminate it, Then start digging but sounds like you have some electronics issues there possibly
__________________
Call 888-744-6542
Old Jan 2, 2008 | 07:26 PM
eduardo's Avatar
Thumbs up
thanks for the response im going to have to take it back so it can get done right.
Old Jan 2, 2008 | 07:28 PM
LS1Tech Sponsor
Ok keep us posted on how things turn out
__________________
Call 888-744-6542
