Tranny swap issue, help needed
I swapped my M6 trans to an A4. Why can't I get it to go into overdrive all the time? It feels like it shifts just fine 1-3, but when it hits 4th the rpms don't drop off like they should. I can feel each gear change and see the tach drop. It has shifted into 4th a handful of times like it is supposed to, I think it does anyway because the rpms drop about 600-800 less than 3rd. What would keep it from acting right. I have done the: "Drive down the road in D at about 50 mph and ride the brakes and gas to see if it's coming out of overdrive." check, with no change in how the tranny acted. the car is an 04' GTO. Any help?
Thanks
Buzz
There are two ways to definatively know if it is in 4th gear. One is to utilize a scanner and watch the command and rpm's. The other is to get it up to speed presumably in 4th and then manually downshift it into 3rd and then back into 4th. If it responds, then you know it is in 4th.
It is possible that you are feeling lock-up. Not likely, but possible.
Feel free to give me a call, wouldn't mind discussing it with you a bit this afternoon.
g
g
Buzz
The converter is not locking up in 4th gear and there is something in the pcm causing it/not letting it lock. WTF? We are at odds as to what it is. We are going to try putting in a stock converter to see if that works and go from there.
Now what about codes? is the dash light on? Things like Misfires or a selenoid slip code will remove lockup even though everything is ok. Also suspect the TCC valve and the PWM selenoid, those would also throw a code.
Now it's possible the clutch could be shot in the converter or infact maybe a bad seal. Worst case you don't have a lockup converter. If you have no codes than changing the converter is probably what I would do.
As mentioned there are several issues that can and will inhibit Lock Up. Misfires are the #1 cause of this, then we see things like exhuast hitting the floor creating an implied detonation, detontation itself can inhibit lock up. Those are just a few.
What you want to do is to see if indeed any of those conditions exist and correct them, I would recommend talking to a Tuner here in the Forums to see what they would do.
I think that replacing the converter is a bit premature, and seems awfully invasive to me at this point in the game. I don't remember the stall speed of your converter.. reresh my memory please. Also, if there is a way for you to inspect the front cover of the converter... the engine side... you are looking for a dark looking discoloration that runs the circumfance (sp) of the unit itself. If you can see this discoloration then the converter clutch has been slipping... if that is not readily apparent I suggest focusing on the tuning.
One thing I would like to know is the TCC enable tables... is there a way for you to convey that info to me?
I will be in and out all day... if you would like to get me on the phone try to do so this afternoon or evening. I'll be happy to discuss this with you again.
Good Luck.
g
I would like to thank the few of you that took the time to respond, give me more avenues to check and helped over the phone. THANKS VERY MUCH!
Buzz
One of the misfire tables wasn't desensitized enough causing the TCC to unlock at low loads when the PCM detected "misfire".
Used the Misfire.cfg to find it...
You can turn off misfire detection as a diagnostic. Then if the TCC locks and stays locked it's just a matter of adjusting the misfire tables for your engine
