th350 temp sensor?
Old Jan 7, 2008 | 07:30 PM
bonnarls1's Avatar
Default th350 temp sensor?
i just put a th350 in my 2000 ls1 firebird,i put the tranny temp sensor in a port on the right side of the tranny,it had a threaded plug in it took out the plug and the sensor fit fine,is that ok there and will it read higher or lower than in the pan? any help thanks
Old Jan 7, 2008 | 08:03 PM
venomhp's Avatar
do you have a picture of where you took the plug out? otherwise IMO youd get better read out of the pan
Old Jan 7, 2008 | 08:07 PM
performabuilt's Avatar
LS1Tech Sponsor
Its one of the presure ports and you can read there, The temps may appear a bit higher than the real average since you are measuring right off the pump and i a small channel of the case, It wont be a good average temperature like you would get in the pan but still will give you and idea,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 8, 2008 | 06:54 AM
bonnarls1's Avatar
Default higher temp's
what do you think 10-15 degrees higher or 15-20? thanks
Old Jan 8, 2008 | 07:53 AM
LS1Tech Sponsor
10 to 20 would be my guess would depend the type driving your doing at the time, On the lower side just normal driving but the spikes would tend to be more when driving agressivley.
__________________
Call 888-744-6542
Old Jan 8, 2008 | 08:55 AM
bonnarls1's Avatar
thanks for your help!!!!!!!!!!!!!!!!!!:
