Is a shift kit a good idea?
Old Jul 2, 2003 | 11:10 PM
maddboost's Avatar
Default Is a shift kit a good idea?
Im planning on having a vig 3800 stall put in my 98 Z28 and am having a shop install it for me. Now this one shop thats doing the install said they dont like doing shift kits they recommend doing a LS1 Edit and just firming up the shift by adjusting the line pressure. But another shop by my house says its a good idea cause the higher stall converter lossens the shifts and the shift kit tightens them back up. what do you guys think?
Old Jul 3, 2003 | 12:48 PM
SS-35th's Avatar
Default Re: Is a shift kit a good idea?
You're going to need your shift points and firmness changed because of the size of your stall. Besides you may pick up a few extra HP if they put your car on a dyno and tune your A/F ratio for you.
Old Jul 3, 2003 | 10:48 PM
maddboost's Avatar
Ok so should I go TransGo shift kit or LS1 Edit to adjust shift firmness?
Old Jul 8, 2003 | 10:10 AM
Plan B's Avatar
Do the Edit first.
Old Jul 9, 2003 | 10:21 AM
megathumpzillaX's Avatar
I'd trust the first shop more as they seem to know the ls1 better. Shiftkit is great if you have a sbc w/out a pcm. Yank says no kit, but don't know about vig.
Old Jul 9, 2003 | 10:39 AM
Jorday's Avatar
The shop that told you the converter will loosen the shifts and the kit will help to tighten them back up is correct. Vig recommends a trans go shift kit with thier converters, I heard from someone. See my other post in this section for more info on shift kit with big converter.
