Vibrating Noise at lock-up
Old Jan 13, 2008 | 08:30 PM
JScamaro's Avatar
Default Vibrating Noise at lock-up
I just had my Yank ss3600 installed and when I reach 40 mph it makes a vibrating noise that seems to come up through the tranny/shifter.
Everywhere else the car drives great but only does this once it locks up at low speeds once I hit 40mph.
Any ideas what this can be?
Old Jan 13, 2008 | 11:41 PM
Camarokid08731's Avatar
i get a vibration in shifter too idk what it is when i hold the **** it seems to stop...idk if thats your prob mine does it because that pins missing out of it that holds it on
Old Jan 14, 2008 | 12:18 AM
LS1 FORMULA's Avatar
Mine does it also from 40 to 45 mph. Whats up with this. Same converter and stall.
Old Jan 14, 2008 | 12:40 AM
sixvi6-camaro's Avatar
sounds like lockup clutch chatter... If it is get it corrected because it can ruin lockup clutches and push pieces of clutch through the trans. If its only doing it at lockup at low speeds have it changed to lockup at 45mph-50mph 4th gear lockup. also set the PWM higher.
Old Jan 14, 2008 | 08:47 AM
jimmyblue's Avatar
Moderator
Yes, sounds like chatter. In addition to eliminating the
TCC PWM function (set min and max duty to 99%) you
may need to increase the steady state line pressure
applied at lower throttle. Either in the General Pressure
tab in HPTuners, if your model has this (yours should,
'02 F) or in the force motor table. General Pressure will
let you add pressure only when locked while force motor
is full time. I had the same problems with my old TCI
and this helped the hooting but was still not enough
for the little clutch to hang on under load.
Old Jan 14, 2008 | 11:00 AM
JScamaro's Avatar
Thanks guys, I'd heading to get the car dyno tuned so I'll have them change the tune.
Update: After I broke in the converter I took my car to MTI to have them dyno tune it. The converter is now silent when it locks up and the car is running great.
