what stall and gear? help me decide
On the converter stall speed... if you are going to be spraying it you'll need a unit that will not blow through when you hit the juice. It will seem a bit tight on motor though. Unfortunately there is not much in between. In other words, a 4,000 or higher unit would not work with the spray.
I would recommend a stall speed in the 3,200 - 3,600 range... that might need to be adjusted depending on which gear you install. I know you are looking for some track duty this year so I would defintely set it up for the N2O by running a tight converter.
g
