yank converter in 02 car
Old Jul 4, 2003 | 01:50 PM
TApimp's Avatar
Default yank converter in 02 car
i remember a while back there was a prob with putting yank converters int o 01 02 cars, anyone remember what it was or how to fix it?
Old Jul 4, 2003 | 02:03 PM
wm_sorg's Avatar
Default Re: yank converter in 02 car
A batch of converters went out in the OCT-DEC 02 time frame with defective splines. They were recalled and replaced by Yank.
Old Jul 4, 2003 | 02:09 PM
TApimp's Avatar
what exactly would it do to the car?
Old Jul 4, 2003 | 11:34 PM
35th LE SS's Avatar
As a general problem, the torque management on the '01 and '02 cars is more severe than on the early years. If you plan on running a high stall, you'll want to delete it with LS1 Edit, Predator, or via a custom tune. This problem isn't just with Yank's but any high stall converter.
Old Jul 5, 2003 | 09:55 AM
Patrick G's Avatar
LS1 Tech Administrator
Yank has completely revised its line of lock-up clutches to address the finicky PCMs on the '01 and later models. The clutches are made from billet steel rather than stamped steel (like the old Yank clutches and the rest of their competitors) and the lining has been revised to dramatically cut down on clutch chatter (a common problem with '01-02s). The new Super Stock converters have all the latest revisions and are worth their premium over the competition in both performance and reliability.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jul 5, 2003 | 10:52 PM
CamaroSS_2002's Avatar
If I plan on purchasing a blower should I upgrade from my PY3600E manufactured in August of 2002 to the new SS4000E?
Blower is going on top of below mods.
Old Jul 6, 2003 | 09:04 AM
Patrick G's Avatar
I would keep the Pro Yank 3600E. It's designed with power adders in mind and works well N/A and with a ton of boost.
__________________
Old Jul 7, 2003 | 11:04 AM
Jorday's Avatar
I have a PT4200 in my 02 Z28. I'd recommend LS1 edit and just turn off torque management completely. There is also one trouble code you may want to turn off. Once I got the converter in my car, I started having some trans issues such as slow 1-2 shift, slow 3-2 downshift, slow converter lockup, slow converter unlock. The biggest of the problems was the 1-2 upshift problem. I ordered a transgo shift kit, installed, and it fixed every problem that I was having. Some guys say that you don't need a trans go, you can fix everything with tuning, but you cant.
With LS1 edit, I tried everything possible to fix that 1-2 shift problem, and It just would not go away. Also, as far as I know, there is no way to even adjust the converter lockup speed unless you change the pulse valve in the valve body. Someone correct me if I'm wrong on that one.
Later,
Jordan
Old Jul 9, 2003 | 10:22 PM
Jpr5690's Avatar
according to a HPP article interview of some engineers for companys like slp they said turning off torque management will gain you a tenth or two but is not worth the harm it causes on your tranny ect. also they said as long as you dont stall over 3400 then you wont need pcm moding but over 34 you throw a code cause it thinks tranny is slipping
