Torque Converter install ISSUE!!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
However, if it is away from the engine and it spins feely then I would suggest it is not damaged. It is possible that the converter to crank pilot is binding keeping you from rotating it while the tranny is flush with the engine. As long as you have not forced anything I believe that you will be ok.
g
So, you did not bolt the tranny housing to the block?
