Digital Trans PSI gauge found!!!!
Old Jan 15, 2008 | 10:07 PM
Turbo V6 Camaro's Avatar
Default Digital Trans PSI gauge found!!!!
I noticed in a search that People can not find gauge's to monitor trans PSI with out putting a line into the cab (which is NHRA no-no)
well Dakota Digital does not list it as working for a trans but i emailed them and they said oil is oil and it will work fine
they have a 0-400 psi sender 2 psi resolution and +/- 8 psi accuracy
Odyssey Series II, Oil Pressure - is the display = $95
SEN-03-5 1/8 / 0 - 400 psi, Universal Pressure Sender $35
$129 plus shipping, (about 10-15 bucks)
i know I'm not very active on here but i though some of you might like to know.
also because of the sender size you may have to get small 1/8 to 1/8 line to move the sender and zip tie/mount it down in the tunnel. not sure as i have to order them and test it out... (hell maybey even a 45* bend will work? )
Old Jan 15, 2008 | 10:19 PM
DopeFedZ's Avatar
I'm using the Aeroforce Interceptor Gauge and it does the same from the OBD port. Nice find though.
Old Jan 15, 2008 | 10:21 PM
cool, but V6 cars don't output the trans PSI only the temp plus isn't that guage like $200 bucks? then again it does like KR and stuff to
Old Jan 15, 2008 | 10:25 PM
performabuilt's Avatar
LS1Tech Sponsor
Cool on the guages , Though the OBD11 can only show anticipated presure as there is not line presure sensor in the trans
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 15, 2008 | 11:08 PM
yeah i only have a line %
Old Jan 20, 2008 | 11:04 AM
renxwar's Avatar
Aren't regular gauges like ~100$? An Interceptor gauge is 230$, requires no wiring, and reads pretty much everything (and from what I understand, 2 things at a time plus a shift light, which would be about ~230$ in gauges, anyway.)
Old Jan 20, 2008 | 11:23 AM
thing is i already have all the other gauges but the KR gauge and with HP tuners i have that already to.....
PLUS at the track i have to use HP Tuners so the other gauge would be useless.
and as already stated buy the sponsor it does not give you true trans psi,.... only what the pcm is expecting it to be.
Old Jan 22, 2008 | 12:14 PM
z-ya's Avatar
B&M sells an electric gauge for under a hundred with the sender..
Old Jan 22, 2008 | 05:00 PM
it only goes to 100 psi least all the ones i can find at summit and there site.... you got a link?
