Got the TransGo installed, and I like it
Old Jun 28, 2004 | 11:46 AM
Jorday's Avatar
whoa, this is an old one.
Yeah, those were the sizes we used when we did mine. Unfortunately, the pump in that transmission died after only a few thousand miles and I replaced the whole transmission. The shifts will be awful harsh with the 3 washers in the 2nd gear accumulator even with the loose converter. I would use 1 washer at most if it was me. I wouldn't mess with line pressure in the trans calibration if you ever have any kind of tuning done now that the shift kit is installed. I'm thinking that excessive line pressure was the cause of my premature pump failure.
Old Jun 28, 2004 | 03:44 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
I have the #3 washer setup with a billet 2-4 servo, running a Y3000 2.0 STR with 3.73's in my 01 Z28. LIFE IS GOOD
SteveC
Old Jun 28, 2004 | 05:05 PM
racingmike's Avatar
where did you get the billet 2-4 servo?
Old Jun 29, 2004 | 07:11 AM
SteveC's Avatar
I purchased it through the transmission shop that did the TC install ($125), it was made by Superior, and "Summit Racing" also sells one.
SteveC
Old Jun 29, 2004 | 05:11 PM
racingmike's Avatar
hey thanks
Old Jun 30, 2004 | 04:17 AM
Atlas's Avatar
Newb question here but when I buy the transgo shift kit do I have to specify which "washer # setup"? TIA
Old Jun 30, 2004 | 05:30 AM
TeamTripp's Avatar
No, it comes with 3 washers and you have the option when you assemble the 1-2 accumulator assembly to decide how many to stick in there.
Old Jun 30, 2004 | 11:46 AM
Colonel's Avatar
Since the 1-2 shift isn't really the problem for the 4L60-E, I'd recommend only 1-2 washers for most high stalled applications and 1 for tight converters. It is in large part a preference thing but bad things can happen if you get it shifting too hard.
The 2-3 and 3-4 shifts are the real problem and the 1-2 accumulator has no effect on them.
Old Jul 1, 2004 | 06:25 PM
1FASTZ28's Avatar
Default Ordering this weekend
I am ordering a Trans Go shift kit this weekend, just wondering how many washers you would use on the stock tranny. Thanx in advance.
Old Jul 2, 2004 | 09:01 AM
SteveC's Avatar
If a professional shop does the install, and goes by the instructions, you should tell them in advance if you do not want the #3 washer setup.
In the instructions it says with higher stall converters use #3 washer. I have that and the shift isn't that harsh at all. Very civilized.
SteveC
Old Jul 2, 2004 | 12:40 PM
Stryker's Avatar
same situation im in. i will eventually be getting a 3500 stall and fms cam but for the next few months it will be stock. there are 3 settings which is recommended for our setups stock????
Old Jul 3, 2004 | 10:28 AM
  #32
Atlas's Avatar
bump about what washer setting for stock trans and converter
