TH350 or 4L60
Old Jan 29, 2008 | 06:08 PM
ls1guy07's Avatar
Default TH350 or 4L60
New to this site but wanted opinions on what to do.I have a 00 Camaro and just broke the lower end of 4l60.Doesnt even have park.I drive it everyday to work but no long trips.It put 450 to wheels on 100 shot and has a small cam only.It went 10.74 @ 125 on 125 in full weight with a yank 3000 converter.Whats the pros and cons on th350?Would I pick up in times with it?What do you have an what times do you run?Thanks guys for input.
Old Jan 29, 2008 | 07:43 PM
LT1hp's Avatar
I was wonding the same thing if you use a 350th will it set a check engine light because all the newer tranny are controled by the ecm,what about the kick down cable ,and the speed o for the mph???but over all the 350 is cheaper and stronger..
