Old Apr 25, 2016, 05:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
Step by Step How to remove 4l60e transmission!!
Old Jan 27, 2010 | 06:08 PM
Joshiedoom's Avatar
Originally Posted by Rickfhvn
I was told when I remove my tranny I need to support my engine because it has more weight in the back and will tilt down and break my dist. cap without the tranny there I thought it will sit fine on the two motor mounts its a 5.7
What engine is this???
Old Apr 16, 2010 | 02:25 PM
1976CamaroGuy's Avatar
what kind of jacks are you using to support the transmissions? I seen the transmission jack adapters and really don't want to spend $50 for one.
I was thinking about taking my extra floor jack and welding a flat steel plate to it...and drill holes to loop a few chains through.
Old May 24, 2010 | 10:33 PM
CBR 900's Avatar
Default help
So I am new here and find what you guys are saying about the removal og the 4L60E tranny, but I have a 96 gmc yukon, and its 4x4, so dropping the other trasfere case is a big ? to me..can someone help..please..
Old Jul 11, 2010 | 03:28 PM
kiztope's Avatar
I'm in process of taking my 4l60 out, and I'm stuck on those dang cooler lines! How in the world do you get to them? It looks like the tranny and engine are lowered as much as they will go, and I can't seem to reach them to get to the clips... Any tricks or contortions that you guys use to get them? Do I need to disconnect the exhaust to get to them?
Old Jul 12, 2010 | 02:18 PM
Camaro Junky's Avatar
Need Pics for the folks that do not like to read the first try!
Old Jul 12, 2010 | 02:25 PM
kiztope's Avatar
To fill anyone in... I had to remove the exhaust Y pipe (snapped a manifold bolt in the process), but after this was removed, the engine dropped low enough to get to the 19mm fittings. I couldn't get the clips off, but was able to reach them with a 19mm wrench.
Next trick - Figuring out how to get the torque converter off... I popped the little cap off of the bottom of the bellhousing, which allows a very limited viewing and I've used the screwdriver method to rotate the flywheel, as described above, but can't seem to find the bolts... maybe I'm missing something obvious here.... I'm back under the car tonight!
Anyone got pics or suggestions on this?
Old Jul 12, 2010 | 06:13 PM
kiztope's Avatar
What a difference another day makes...
In the interest of making this thread as valuable as possible, I'll just keep answering my own questions here as well!
I found that there is a black plastic cover on the passenger side of the car, at the front of the transmission, with a single 10mm bolt holding it on. Once off, you have access to the flywheel/flexplate and the 3 torque converter bolts.
Old Aug 17, 2010 | 11:40 AM
oldNslow89TA's Avatar
what all differences would a 4L60E mated to an LT1 be to remove?? Hope my bellhousing bolts don't take 3-6hrs, but it will be on a lift.
Old Feb 3, 2011 | 09:07 PM
bmf5150's Avatar
What are torque specs for the 4l60e bellhousing to the engine!
Old Mar 17, 2011 | 07:03 PM
Klaus34's Avatar
I use the German torque specs gud n tite
Old Mar 17, 2011 | 07:23 PM
senicalj4579's Avatar
35-37'lbs I believe
Old Aug 11, 2011 | 12:22 AM
  #32
bobbyk3lly's Avatar
thanks guys, im going to be taking my trans out tomorrow and this helped alot with what i needed so i know how and what to do to get this thing out.. wish me luck, first time im ever done a trans job, so god i hope this works
Old Aug 11, 2011 | 08:26 AM
  #33
a-low's Avatar
Here's a more detailed one
http://modernmusclecars.net/forums/a...p?do=tcinstall
Old Aug 11, 2011 | 08:43 AM
  #34
Originally Posted by a-low
Thats the one I went by.
Old May 16, 2013 | 06:47 PM
  #35
Shawz's Avatar
Having trouble reconnecting the cooler lines to side of tranny, fittings will not screw in, had to remove them cause that would not separate when e clips where off
Old Sep 6, 2013 | 07:22 PM
  #36
NTrafficCC's Avatar
Originally Posted by bjamick
Before messing with anything always, ALWAYS disconnect the battery .
Step one: Chalk the front tires and jack up the rear of the car. Put car in Neutral (Apprx time 3-5min)
2.) Grab a 3/8 Socket and ratchet. Take off the 4 bolts holding the driveshaft on. If you cant get to the bolts turn the driveshaft with your hands. Once you get the driveshaft into the right spot. Climb out from underneath the car and yank the E-brake and get back underneath the car and take the bolts off. Repeat for the other 2 bolts. Then just remover driveshaft. (Apprx time 8-12min)
Now you can lower the rear back onto the ground. (apprx time 2-3min)
Chalk the rear tires now. Then jack up the front and put your jack stands to hold the car up. It has to be pretty high. (apprx time 8-10min)
3.) Now go ahead and remove your starter with a 15mm socket. There are 2 bolts holding it on. Then remove the 2 wires that are on the starter not for sure on sizes. (apprx time 5-8min)
4.) Grab your jack and put it on the trans pan. Start loosening the crossmember bolts. There are 5 bolts holding the crossmember on. All are 15mm. (apprx time 3-6min)
5.) steadily let the jack down until you can see the cooler lines running out the passenger side of the tranny. Once you can see them tighten the jack back up and start disconnecting the cooler lines. (Have a bucket handy to catch the fluid. (Dont remember what the size is sorry.) (apprx time 15-25min)
6.) Now unplug all electric connectors (ex VSS (speedo sensor, its the big green connector) one on the tailshaft, shifter cable, and your 02 sensors). (apprx time 1-3min)
7.) Remove the brackets holding the torque arm in place. There are 3 bolts holding this on. One on top and 2 on the bottom. Watch your hands bc the torque arm can pull up really hard and fast sometimes when loose. (apprx time 5-7min)
8.) Now comes the fun part, you need to unbolt the converter from the flexplate. GM used allen head torque converter bolts in 98 and they are a pretty nice size. 99+ i believe came with actual bolts. You figure out what size fits best . You will need to have a nice sized flat head screwdriver to turn the flexplate by hand so you can get to the converter bolts. (There are 3 of them). (apprx time 10-15min)
9.) Now get a 13mm socket and all your extensions. Start removing the bellhousing bolts (There are 8 of them). This takes alot of time and alot of patience to get this step done. (apprx time 3-6 hours)
10.) Once you got all the bellhousing bolts out the trans will be probably stuck to the engine. you will need to get that flathead screwdriver you used for the converter. Use it as a wedge to pry the tranny from the engine. Make sure your jack is ready to take the weight when you get the tranny separated.
This is when you find out if you jacked up the front of the car enough . If you didn't then you will prob have to slide the tranny out by hand. Which isn't to bad but its alot easier with it on a jack . (apprx time 3-4min)
There ya go, the steps and est. time involved in removing a tranny. I wish someone would sticky this for all the new guys that ask this particular question.
Hope this help many people.
Can you install a 4l60e from a 2000 Tahoe in a 1997 suburban?
Old Mar 31, 2014 | 10:17 PM
  #37
adamc314's Avatar
New to the whole LS car thing, so this is probably a stupid question, what size are the tranny pan bolts on the 4l60 in a trans am? I can't seem to find the bolt size anywhere and I'm missing one
Old Mar 31, 2014 | 10:31 PM
  #38
mrvedit's Avatar
Moderator
All '97 have a 298mm input shaft and assuming the 2000 Tahoe has a V8 (LS1) engine, its trans will have a 300mm input shaft. It won't even bolt up - the converter will bottom out in the crank with the bellhousing about 1" from the engine.
In short if the 2000 Tahoe had a V8 engine, no.
Old Feb 8, 2015 | 02:47 AM
  #39
stngh8r's Avatar
Thumbs up
To OP. Thank you.
Old Feb 11, 2015 | 02:04 AM
  #40
stngh8r's Avatar
Question
Any tips on the cooler lines? I'm stuck.
