newbie to this converter stuff.. few ??'s
Some basics to think about with the converter. They allow your engine to spin up to a set RPM level before the driveline fully engages and you smoke your tires. The higher the stall rating the higher you can rev at the light before breaking the wheels loose. The higher you can rev at launch the higher you are in your power band.
Even if you don't rev up the car at a higher stall, the amount of time it takes to run up to 2,800 RPMs when you let go of the brake and stab the gas is practilly the same amount of time it takes to hit 3,500-4,400 RPMs. The only real differnce is how much HP and TRQ your car is putting down when the driveline actually engages and the wheel go.
This is why the torque converter is probably the single biggest bang for the buck on an automatic.
Read up at Yank's page as suggested above for the techical explaination of how Stall Speed, STR and converter efficiency play together.
You'll be in need of a set of Nitto drag radials to match up with your new converter. If you're a daily driver in the Detroit area and only getting to the track a few times a year, look at the SY-3500, SS-3600, Vig 3200 or Vig 3600. ;D
Rick
