Having tranny installed tom (A4) any tidbits?
Any gotchas???
Kenny
Other tips:
1. Make sure you have an 8mm allen for the verter bolts
2. Dont lose the tranny line snap rings
3. If not using a lift make sure car is as high as your stands will allow
4. A 13mm universal socket and BMF extension make the bellhousing bolts VERY easy
5. Remove the passenger side heat shielding (prevents DEEP cuts!!)
Kenny
