How to Dyno a Car with vig 3200 stall
Old Feb 9, 2003 | 02:41 PM
flyin red TA's Avatar
Default Re: How to Dyno a Car with vig 3200 stall
Do you have a lockup switch? It helps.
What gears? Can't really give you any advice without that info.
Old Feb 9, 2003 | 02:43 PM
TomQ's Avatar
no lock up switch
stock shift points, 6500 rev limiter
3.42 gears
also will be spraying 100-150 wet
Old Feb 9, 2003 | 03:20 PM
Colonel's Avatar
Get a lockup switch or use a Tech II to lock the converter.
Old Feb 9, 2003 | 04:04 PM
TomQ's Avatar
can i lock the converter with ls1edit?
if so, how to ?
Old Feb 9, 2003 | 04:39 PM
Ragtop 99's Avatar
In edit:
1) set your 3-2 downshift not to occur at speeds over 40 mph.
2) set the 3rd gear lock-up to occur at WOT (and at 94%/100% on the lock-up table) at 55 mph.
On the dyno leave the car in D and punch it from 42 mph. engage the dyno's recorder at 60 mph and you'll have an accurate curve from about 3000 rpm up.
Old Feb 9, 2003 | 05:15 PM
TomQ's Avatar
Thank you Ragtop !!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 10, 2003 | 12:09 AM
TomQ's Avatar
Default How to Dyno a Car with vig 3200 stall
the subj,
just need some words of wisdom
