new tranny slipping
Tranny is a 65E and they built it as strong as possible, beast sun shell, transgo shift kit ect. Converter specialist built a 3000 stall for it. Been working fine but other night was slipping really bad in first. shifts into 2nd really soft now to and stalls little. parked it took it back to AMMCO tonight. ??
Fluid is burnt-level is fine - Converter going out, lock up not working??
read some where about deleting tork management? wut is that about could that have caused problem?
I've seen my 4L80E run at 240* over small mountains in a fullsized truck fully loaded towing my camaro on a trailer and the fluid still looks and smells new.
You had to be running more than 130* to burn fluid, when you get this trans fixed you might want to check the sender for the temp gauge to prevent further problems.
